Timber Doorsets
Depending on your requirements, Pendle Doors can design and manufacture timber doorsets that are easy to assemble, reliable and fit for purpose. Once ordered, a doorset will arrive with all of the individual components included in one package, including the door, frame, ironmongery and vision panels, which will be ready for assembly as soon as it is unwrapped.
Most importantly, your doorset will be ready to perform the specialist function you have requested, from being fire resistant, to performing ideally in an acoustically controlled environment. It is paramount that we identify what kind of environment the door will be used in, as we can then recommend a specific door type that will work best in a school, hospital, leisure centre, designer home, or local authority building.
In addition, the design of your doorset will fit your exact requirements in colour, dimensions, and finish. Whether it is veneered, laminated, primed or fully factory finished, we can provide the right doorset for you.
If you have any questions regarding our products or you would like to order a doorset that will meet your requirements, get in touch.
Defender Range
Our defender range is represented by External PAS 24 Secured By Design doorsets, which are available in a large range of designs.
Guardian Fire Door
Our Guardian Fire doors can be manufactured to FD 30, FD60, FD90 and FD120 specification and are available in paint grade, veneered, laminate and acrovyn finishes.
Healthcare Range
We offer both HTM and X-Ray doors, in a variety of thicknesses. Projects completed include mental health units, clinics, hospitals and other medical facilities.
Soundwave Range
Acoustic doors are manufactured to the db rating suitable for areas where sound isolation/privacy is required in accordance to technical specifications supplied by our clients.
Triple "S" Range
Internal PAS 24 FD30 Flat Entrance Doorsets – are available in a wide range of finishes.
